Intermittent random shut downs Late 2013 MBP
So I have a from new 15” Late 2013 Macbook Pro. In the last month or so I have been plagued by random black screen kernal panics and restarts. There doesn’t exactly seem to be any rhyme or reason to the crashes. I can push it quite hard in Davinci Resolve or with multiple large tiff files in photoshop at the same time without any issues but then it might crash while just browsing a webpage or watching youtube. If I can hear my fans spinning up or the MBP getting hot it might crash but not always, at least 50% of the time it will continue working fine until it crashes after everything has calmed down at a later point.
I have tried replicating the problem but there doesn’t seem to be any real pattern or anything that sets it off. The only reasonably consistent pattern is when it wakes up after hibernation, it will often kernal panic and black screen crash at that point but even that isn’t consistent. It is really starting to become anonying as I use my MBP for extensive photo editing and colour grading and crashes mid operation is very frustrating.
I have attached my Etrecheck report, which seems to imply it may be related to one of
  at.obdev.nke.LittleSnitch
            com.box.filesystems.osxfuse
            com.codexdigital.driver.usbDockDriver
            com.paceap.kext.pacesupport.snowleopard
            com.sony.driver.dsccamDeviceInfo00
            com.sony.driver.sxsus10drivers
            com.sony.driver.sxsxqddrivers
            com.sony.scsi.SR-D1
Although these are all programs or support files that I have had installed for many years, albeit they have been updated at various points. I have tried uninstalling a few items but most of them I absolutely need. I am willing to go back to an older version if absoltely neccesay.
Any advice that can be suggested would be greatly appreciated.
EtreCheckPro version: 6.2.6 (6C020)
Report generated: 2020-06-06 11:40:47
'''Download EtreCheckPro from https://etrecheck.com'''
Runtime: 5:29
Performance: Below Average
Problem: Computer is restarting
Major Issues:
    Anything that appears on this list needs immediate attention.
    No Time Machine backup - Time Machine backup not found.
    Kernel panics - This system has experienced kernel panics that could be related to 3rd party software.
Minor Issues:
    These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
    Heavy RAM usage - Apps are using a large amount of RAM.
    High battery cycle count - Your battery may be losing capacity.
    Apps crashing - There have been numerous app crashes.
    Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage.
    Clean up - There are orphan files that could be removed.
    Unsigned files - There are unsigned software files installed. Apple has said that unsigned software will not run by default in a future version of the operating system.
    System modifications - There are a large number of system modifications running in the background.
    Low performance - EtreCheck report took an unusually long time to run.
    32-bit Apps - This machine has 32-bits apps will not work on macOS 10.15 "Catalina".
    Kernel extensions present - This machine has kernel extensions that may not work in the future.
    Sharing enabled - This machine has sharing services enabled that could be a security risk.
Hardware Information:
    MacBook Pro (Retina, 15-inch, Late 2013)
    MacBook Pro Model: MacBookPro11,3
    2.6 GHz Intel Core i7 (i7-4960HQ) CPU: 4-core
    16 GB RAM - Not upgradeable
        BANK 0/DIMM0 - 8 GB DDR3 1600
        BANK 1/DIMM0 - 8 GB DDR3 1600
    Battery: Health = Replace Soon - Cycle count = 1387
Video Information:
    Intel Iris Pro - VRAM: 1536 MB
    NVIDIA GeForce GT 750M - VRAM: 2 GB
        Color LCD (built-in) 2880 x 1800
Drives:
    disk0 - APPLE SSD SM1024F 1.00 TB (Solid State - TRIM: Yes)
    Internal PCI 5.0 GT/s x4 Serial ATA
        disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
        disk0s2 [APFS Container] 1.00 TB
            disk1 [APFS Virtual drive] 1.00 TB (Shared by 4 volumes)
                disk1s1 - Macintosh HD (APFS) (Shared - 725.83 GB used)
                disk1s2 - Preboot (APFS) [APFS Preboot] (Shared - 43 MB used)
                disk1s3 - Recovery (APFS) [Recovery] (Shared - 510 MB used)
                disk1s4 - VM (APFS) [APFS VM] (Shared - 1.07 GB used)
Mounted Volumes:
        1.00 TB (Shared - 725.83 GB used, 276.53 GB available, 272.68 GB free)
        APFS
        Mount point: /
    disk1s4 - VM [APFS VM]         1.00 TB (Shared - 1.07 GB used, 272.68 GB free)         APFS         Mount point: /private/var/vm
Network:
    Interface en0: Wi-Fi
        802.11 a/b/g/n/ac
    Interface en3: Bluetooth PAN
    Interface bridge0: Thunderbolt Bridge
    Interface en4: Ethernet Adaptor (en4)
    Interface en5: Thunderbolt Ethernet
    Interface fw0: Thunderbolt FireWire
    File sharing: Enabled
    Printer sharing: Enabled
System Software:
    macOS Mojave 10.14.6 (18G5033)
    Time since boot: Less than an hour
Configuration Files:
    File /etc/sysctl.conf exists but not expected
    /etc/hosts - Count: 1
Notifications:
    SpyderUtility.app
        24 notifications
    Little Snitch Agent.app
        3 notifications
Security:
    Gatekeeper: App Store and identified developers
    System Integrity Protection: Enabled
    Antivirus software: Apple
Unsigned Files:
    Launchd: /Library/LaunchDaemons/com.daisydiskapp.DaisyDiskAdminHelper.plist
        Executable: /Library/PrivilegedHelperTools/com.daisydiskapp.DaisyDiskAdminHelper
        Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.nvidia.cuda.launcher.plist         Executable: /Library/PreferencePanes/CUDA Preferences.prefPane/Contents/Resources/CUDAd.sh start         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.gspeed2.httpd.plist         Executable: /Applications/G-SPEED Software Utility.app/Contents/Resources/apache2/bin/httpdgs -f '/Applications/G-SPEED Software Utility.app/Contents/Resources/apache2/conf/httpd.conf'         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.avid.interplay.editorbroker.plist         Executable: ./RunAvidEditorBroker.bash /Applications/Avid/EditorTranscode/DBScript 0         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.dmfsupportsvc.plist         Executable: /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidDMFSupportSvc.app/Contents/MacOS/AvidDMFSupportSvc         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Java-Updater.plist         Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguard9.plist         Executable: /bin/sh -c $HOME/Library/Cisco/VideoGuardPlayer/VideoGuard9/VideoGuard9.bundle/Contents/Resources/setupServer.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.gspeed2.emaildg.plist         Executable: /Applications/G-SPEED Software Utility.app/Contents/Resources/emaildg         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.interplay.dmfservice.plist         Executable: /Applications/Avid Media Composer/DMFService.app/Contents/MacOS/DMFService         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/PACESupport.plist         Executable: /System/Library/Extensions/PACESupportFamily.kext/Contents/Resources/paceload         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.softraid.softraidd.plist         Executable: softraidd         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.avid.interplay.editortranscodestatus.plist         Executable: ./AvidEditorTranscodeStatusMac.bash /Applications/Avid/EditorTranscode/rnc-central 0         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguard9.uninstall.plist         Executable: /bin/sh ~/.cisco/VideoGuard/uninstall/cisco_videoguard9/condUninstall.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.softraid.SoftRAIDMonitor.plist         Executable: /Library/Extensions/SoftRAID.kext/Contents/Resources/SoftRAID_Monitor.app/Contents/MacOS/SoftRAID_Monitor         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.ApplicationManager.plist         Executable: /Applications/Avid/Application Manager/AvidApplicationManager.app/Contents/MacOS/AvidApplicationManager --trayonly         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguard10.uninstall.plist         Executable: /bin/sh ~/.cisco/VideoGuard/uninstall/cisco_videoguard10/condUninstall.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.backgroundservicesmanager.plist         Executable: /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidBackgroundServicesManager.app/Contents/MacOS/AvidBackgroundServicesManager         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.edb.launchd.postgresql-8.4.plist         Executable: /Library/PostgreSQL/8.4/bin/postmaster -D/Library/PostgreSQL/8.4/data         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguard10.plist         Executable: /bin/sh -c $HOME/Library/Cisco/VideoGuardPlayer/VideoGuard10/VideoGuard10.bundle/Contents/Resources/setupServer.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguard7.plist         Executable: /bin/sh -c $HOME/Library/Cisco/VideoGuardPlayer/VideoGuard7/VideoGuard7.bundle/Contents/Resources/setupServer.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguard7.uninstall.plist         Executable: /bin/sh ~/.cisco/VideoGuard/uninstall/cisco_videoguard7/condUninstall.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.oracle.java.JavaUpdateHelper.plist         Executable: /Library/PrivilegedHelperTools/com.oracle.java.JavaUpdateHelper         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.vladalexa.MagicPrefs.plist         Executable: /Applications/MagicPrefs.app/Contents/MacOS/MagicPrefs         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.transcodeserviceworker.plist         Executable: /Applications/Avid/EditorTranscode/TranscodeService/TranscodeServiceWorker.app/Contents/MacOS/TranscodeServiceWorker /Applications/Avid/EditorTranscode/TranscodeService         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist         Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.gspeed2.bgaschedg.plist         Executable: /Applications/G-SPEED Software Utility.app/Contents/Resources/bgaschedg         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.interplay.editortranscode.plist         Executable: /Applications/Avid/EditorTranscode/TranscodeService/EditorTranscode.app/Contents/MacOS/RunEditorTranscode.bash         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist         Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Helper-Tool.plist         Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.gspeed2.BGPMain_G.plist         Executable: /Applications/G-SPEED Software Utility.app/Contents/Resources/XMLBase/BGPMain_G         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.codexdigital.drserver.plist         Executable: /usr/local/codex/bin/drserver         Details: Exact match found in the whitelist - probably OK
    Launchd: ~/Library/LaunchAgents/com.cisco.videoguardmonitor.plist         Executable: /bin/sh -c $HOME/Library/Cisco/VideoGuardPlayer/VideoGuardMonitor/VideoGuardMonitor.bundle/Contents/Resources/launch.sh         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.avid.ApplicationManagerHelper.plist         Executable: /Applications/Avid/Application Manager/AvidAppManHelper.app/Contents/MacOS/AvidAppManHelper         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchAgents/com.dymo.dls.webservice.plist         Executable: /Library/Frameworks/DYMO/SDK/DYMO.DLS.Printing.Host.app/Contents/MacOS/DYMO.DLS.Printing.Host         Details: Exact match found in the whitelist - probably OK
    Launchd: /Library/LaunchDaemons/com.paceap.eden.licensed.plist         Executable: /Library/PrivilegedHelperTools/licenseDaemon.app/Contents/MacOS/licenseDaemon --backurl https:/activation.paceap.com/InitiateActivation         Details: Exact match found in the whitelist - probably OK
    Running app: /Applications/Capture One 20.app/Contents/MacOS/Capture One 20 -psn_0_53261     Running app: /Applications/REDCINE-X Professional/Utilities/RED Watchdog.app/Contents/MacOS/RED Watchdog     Running app: ~/Library/Application Support/Sony Ericsson Bridge for Mac/Sony Ericsson Bridge Helper.app/Contents/MacOS/Sony Ericsson Bridge Helper
    Login Item: /Applications/REDCINE-X Professional/Utilities/RED Watchdog.app     Login Item: ~/Library/Application Support/Sony Ericsson Bridge for Mac/Sony Ericsson Bridge Helper.app
    Plugin: /Library/Internet Plug-Ins/PMCADownloader.plugin     Plugin: /Library/Internet Plug-Ins/nplastpass.plugin     Plugin: /Library/Internet Plug-Ins/Silverlight.plugin     Plugin: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin
    Preference Pane: /Library/PreferencePanes/Codex.prefPane     Preference Pane: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/deploy/JavaControlPanel.prefPane     Preference Pane: ~/Library/PreferencePanes/MagicPrefs.prefPane
    Apps: 49
32-bit Applications:
    47 32-bit apps
Kernel Extensions:
    /Applications/Capture One 12.app
        [Not Loaded] LeafFwXDriverMatcher64.kext (Phase One A/S, 1.2.0d1)
    /Applications/DiskWarrior.app         [Not Loaded] DiskWarriorPreview.kext (Alsoft, Inc, 5.2 - SDK 10.5)
    /Applications/InsomniaX.app         [Not Loaded] Insomnia_r11.kext (Andrew James, 2.1.7 - SDK 10.9)
    /Applications/Lytro Desktop.app         [Not Loaded] LytroFirefly.kext (Lytro Inc., 4.3.3 - SDK 10.10)
    /Library/Application Support/CleverFiles/BackService.app         [Not Loaded] SecureDisk.kext (Justin Johnson, 1.0 - SDK 10.12)
    /Library/Extensions         [Loaded] LittleSnitch.kext (Objective Development Software GmbH, 4.4.3 - SDK 10.11)         [Not Loaded] DeckLink_Driver.kext (Blackmagic Design Inc, 10.8 - SDK 10.9)         [Not Loaded] Blackmagic_Multibridge_Driver.kext (Blackmagic Design Inc, 10.8 - SDK 10.9)         [Not Loaded] BlackmagicIO.kext (Blackmagic Design Inc, 10.8 - SDK 10.9)         [Not Loaded] BlackmagicUsbIO.kext (Blackmagic Design Inc, 10.8 - SDK 10.9)         [Not Loaded] CodexDigitalTbtDockDriver.kext (Codex Digital Ltd , 1.0.0d1 - SDK 10.10)         [Not Loaded] CodexDigitalUSB3DockDriver.kext (Codex Digital Ltd , 1.0 - SDK 10.10)         [Not Loaded] DymoUsbPrinterClassDriver.kext (Sanford, L.P., 1.1 - SDK 10.12)         [Not Loaded] CUDA.kext (NVIDIA Corporation, 1.1.0)         [Not Loaded] GSpeedShuttleIcon.kext (HGST, Inc., 2.0.5 - SDK 10.11)
    /System/Library/Extensions         [Not Loaded] AvidDX.kext (5.9.0 - SDK 10.8)         [Not Loaded] Sentinel.kext (7.5.2)         [Not Loaded] PACESupportFamily.kext (5.9.1 - SDK 10.6)         [Not Loaded] SONYDeviceType04.kext (Sony Corporation, 1.3.0.06030 - SDK 10.10)         [Not Loaded] SxSLogicalUnitDriverExpress.kext (Sony Corporation, 2.1.1d003 - SDK 10.6)         [Not Loaded] SxSLogicalUnitDriverUS10.kext (Sony Corporation, 2.1.1d003 - SDK 10.6)         [Not Loaded] SxSLogicalUnitDriverXQD.kext (Sony Corporation, 2.1.1d003 - SDK 10.6)         [Not Loaded] SxSLogicalUnitDriverXQDExpress.kext (Sony Corporation, 2.1.1d003 - SDK 10.6)         [Not Loaded] SrFAMFS.kext (Sony Corporation, 1.54.0d003 - SDK 10.6)         [Not Loaded] sxsudf_fs.kext (Sony Corporation, 2.1.1d003 - SDK 10.6)         [Not Loaded] SxS Memory Card.kext (1.1.2.10220 - SDK 10.6)         [Not Loaded] AXSMem.kext (Sony Corporation, 1.3.1.1 - SDK 10.6)         [Loaded] SRMem.kext (Sony Corporation, 1.54.0d003 - SDK 10.6)
Startup Items:
    HW_CreateNetwork Path: /Library/StartupItems/HW_CreateNetwork
    HWPortDetect_driver Path: /Library/StartupItems/HWPortDetect_driver
System Launch Agents:
    [Not Loaded] 16 Apple tasks
    [Loaded] 169 Apple tasks
    [Running] 115 Apple tasks
System Launch Daemons:
    [Not Loaded] 34 Apple tasks
    [Loaded] 185 Apple tasks
    [Running] 116 Apple tasks
Launch Agents:
    [Running] at.obdev.LittleSnitchHelper.plist (Objective Development Software GmbH - installed 2020-03-17)
    [Running] at.obdev.LittleSnitchUIAgent.plist (Objective Development Software GmbH - installed 2020-03-17)
    [Not Loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2019-03-08)
    [Other] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2020-05-09)
    [Running] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2019-03-08)
    [Running] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2020-05-10)
    [Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-05-10)
    [Running] com.avid.ApplicationManager.plist (? 15a48a0 - installed 2014-12-18)
    [Running] com.avid.ApplicationManagerHelper.plist (? 6a974dc2 - installed 2014-12-18)
    [Other] com.avid.backgroundservicesmanager.plist (? 133f6fbb - installed 2014-12-19)
    [Loaded] com.avid.dmfsupportsvc.plist (? fd1658c4 - installed 2014-12-19)
    [Loaded] com.avid.interplay.dmfservice.plist (? 76315928 - installed 2014-12-19)
    [Loaded] com.avid.interplay.editortranscode.plist (? 3be95b8d - installed 2014-12-19)
    [Loaded] com.avid.transcodeserviceworker.plist (? ab3f9dad - installed 2014-12-19)
    [Running] com.blackmagic-design.DesktopVideoFirmwareUpdater.plist (Blackmagic Design Inc - installed 2016-09-05)
    [Running] com.box.desktop.helper.plist (Box, Inc. - installed 2020-05-10)
    [Running] com.dymo.dls.webservice.plist (? 77c41eb - installed 2019-02-02)
    [Other] com.nvidia.CUDASoftwareUpdate.plist (NVIDIA Corporation - installed 2019-04-19)
    [Not Loaded] com.oracle.java.Java-Updater.plist (? 921cccca - installed 2015-03-13)
    [Other] com.softraid.SoftRAIDMonitor.plist (? b9fa4cd6 - installed 2015-04-02)
    [Not Loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2017-03-14)
    [Not Loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2017-03-14)
Launch Daemons:
    [Loaded] PACESupport.plist (? ab6b5614 - installed 2013-02-01)
    [Running] at.obdev.littlesnitchd.plist (Objective Development Software GmbH - installed 2020-03-17)
    [Loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2020-04-21)
    [Loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2020-04-21)
    [Loaded] com.adobe.acc.installer.v2.plist (Adobe Systems, Inc. - installed 2019-03-08)
    [Running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2020-05-10)
    [Loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2020-04-24)
    [Loaded] com.apple.installer.osmessagetracing.plist (Apple - installed 2020-05-20)
    [Running] com.avid.interplay.editorbroker.plist (? dbf8b72b - installed 2014-12-19)
    [Running] com.avid.interplay.editortranscodestatus.plist (? ed44ae64 - installed 2014-12-19)
    [Running] com.blackmagic-design.DesktopVideoHelper.plist (Blackmagic Design Inc - installed 2016-09-05)
    [Loaded] com.blackmagic-design.desktopvideo.XPCService.plist (Blackmagic Design Inc - installed 2016-09-05)
    [Running] com.blackmagic-design.streaming.BMDStreamingServer.plist (Blackmagic Design Inc - installed 2016-09-05)
    [Running] com.box.desktop.autoupdater.plist (Box, Inc. - installed 2020-05-10)
    [Running] com.cleverfiles.cfbackd.plist (Justin Johnson - installed 2019-04-02)
    [Loaded] com.codexdigital.drserver.plist (? 94d83acc - installed 2015-03-12)
    [Running] com.codexdigital.offloader.plist (Codex Digital Ltd - installed 2015-03-12)
    [Loaded] com.daisydiskapp.DaisyDiskAdminHelper.plist (? de20d690 - installed 2019-03-21)
    [Running] com.dymo.pnpd.plist (Sanford, L.P. - installed 2019-02-02)
    [Loaded] com.edb.launchd.postgresql-8.4.plist (? 42ee2393 - installed 2015-01-14)
    [Running] com.gspeed2.BGPMain_G.plist (? 1aae0e5 - installed 2018-04-11)
    [Loaded] com.gspeed2.bgaschedg.plist (? 93e1f63d - installed 2018-04-11)
    [Loaded] com.gspeed2.emaildg.plist (? 270ba395 - installed 2018-04-11)
    [Loaded] com.gspeed2.httpd.plist (? a78dcfdc - installed 2018-07-24)
    [Loaded] com.ipvanish.osx.vpnhelper.plist (Mudhook Marketing, Inc. - installed 2018-10-21)
    [Loaded] com.nvidia.cuda.launcher.plist (? 20f73770 - installed 2019-04-19)
    [Loaded] com.nvidia.cudad.plist (NVIDIA Corporation - installed 2019-04-19)
    [Not Loaded] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installed 2015-03-13)
    [Loaded] com.oracle.java.JavaUpdateHelper.plist (? 3298096d - installed 2015-03-24)
    [Running] com.paceap.eden.licensed.plist (? 80d4f3b9 - installed 2014-01-16)
    [Other] com.softraid.softraidd.plist (? 90efd1b5 - installed 2015-04-02)
    [Loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2017-03-14)
    [Not Loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2017-03-14)
User Launch Agents:
    [Loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2019-03-08)
    [Loaded] com.cisco.videoguard10.plist (? 0 - installed 2019-09-21)
    [Loaded] com.cisco.videoguard10.uninstall.plist (? 0 - installed 2019-09-21)
    [Loaded] com.cisco.videoguard7.plist (? 0 - installed 2019-09-21)
    [Loaded] com.cisco.videoguard7.uninstall.plist (? 0 - installed 2019-09-21)
    [Loaded] com.cisco.videoguard9.plist (? 0 - installed 2019-09-21)
    [Loaded] com.cisco.videoguard9.uninstall.plist (? 0 - installed 2019-09-21)
    [Running] com.cisco.videoguardmonitor.plist (? 0 - installed 2019-09-21)
    [Loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2019-08-21)
    [Loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2020-03-12)
    [Loaded] com.google.keystone.xpcservice.plist (Google, Inc. - installed 2020-03-12)
    [Other] com.vladalexa.MagicPrefs.plist (? 0 - installed 2014-01-10)
User Login Items:
    [Not Loaded] AirDroidHelper (Sand Studio - installed 2018-10-19)
        Modern Login Item
        /Applications/AirDroid.app/Contents/Library/LoginItems/AirDroidHelper.app
    [Running] Backup and Sync (Google, Inc. - installed 2020-05-06)         Application         /Applications/Backup and Sync.app
    [Running] Box (Box, Inc. - installed 2020-05-14)         Application         /Applications/Box.app
    [Running] SpyderUtility (Datacolor - installed 2019-11-21)         Application         /Applications/Datacolor/Spyder5Elite/Support/SpyderUtility.app
    [Loaded] DiskWarriorStarter (Alsoft, Inc - installed 2018-09-28)         Application         /Applications/DiskWarrior.app/Contents/Helpers/DiskWarriorStarter.app
    [Running] Dropbox (Dropbox, Inc. - installed 2020-05-29)         Application         /Applications/Dropbox.app
    [Not Loaded] IPVLauncher (Mudhook Marketing, Inc. - installed 2018-10-21)         Modern Login Item         /Applications/IPVanish VPN.app/Contents/Library/LoginItems/IPVLauncher.app
    [Running] InsomniaX (Andrew James - installed 2014-10-11)         Application         /Applications/InsomniaX.app
    [Running] LytroHelper (Lytro Inc. - installed 2015-11-19)         Modern Login Item         /Applications/Lytro Desktop.app/Contents/Library/LoginItems/LytroHelper.app
    [Running] RED Watchdog (? - installed 2017-05-09)         Application         /Applications/REDCINE-X Professional/Utilities/RED Watchdog.app
    [Not Loaded] Slack Login Helper (App Store - installed 2020-05-31)         Modern Login Item         /Applications/Slack.app/Contents/Library/LoginItems/Slack Login Helper.app
    [Not Loaded] StartUpHelper (Spotify - installed 2020-04-10)         Modern Login Item         /Applications/Spotify.app/Contents/Library/LoginItems/StartUpHelper.app
    [Not Loaded] PhotoStreamAgent (App Store - installed 2038-01-19)         Modern Login Item         /Applications/iPhoto.app/Contents/Library/LoginItems/PhotoStreamAgent.app
    [Running] SmartDaemon (Justin Johnson - installed 2019-04-02)         Application         /Library/Application Support/CleverFiles/SmartDaemon.app
    [Not Loaded] HP Device Monitor (HP Inc. - installed 2017-12-11)         Modern Login Item         /Library/Printers/hp/Frameworks/HPDeviceMonitoring.framework/Versions/1.0/Helpers/HP Device Monitor Manager.app/Contents/Library/LoginItems/HP Device Monitor.app
    [Not Loaded] HP Product Research (HP Inc. - installed 2017-12-11)         Modern Login Item         /Library/Printers/hp/Utilities/HPPU Plugins/ProductImprovementStudy.hptask/Contents/Helpers/HP Product Research Manager.app/Contents/Library/LoginItems/HP Product Research.app
    [Running] Android File Transfer Agent (Google, Inc. - installed 2018-10-17)         Application         ~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app
    [Running] Sony Ericsson Bridge Helper (? - installed 2016-03-28)         Application         ~/Library/Application Support/Sony Ericsson Bridge for Mac/Sony Ericsson Bridge Helper.app
Internet Plug-ins:
    AdobeAAMDetect: 3.0.0.0 (Adobe Systems, Inc. - installed 2019-03-08)
    FlashPlayer-10.6: 32.0.0.371 (Adobe Systems, Inc. - installed 2020-05-12)
    AdobePDFViewerNPAPI: 17.012.20098 (Adobe Systems, Inc. - installed 2020-06-03)
    DYMO NPAPI Addin: 1.0 (Sanford, L.P. - installed 2019-10-18)
    AdobePDFViewer: 20.009.20067 (Adobe Systems, Inc. - installed 2020-06-03)
    PMCADownloader: 1.3.0.06130 (? - installed 2017-10-03)
    Flash Player: 32.0.0.371 (Adobe Systems, Inc. - installed 2020-05-12)
    nplastpass: 3.1.21 (? - installed 2014-08-27)
    DYMO Safari Addin: (Sanford, L.P. - installed 2019-10-18)
    Silverlight: 5.1.30317.0 (? - installed 2014-04-20)
    JavaAppletPlugin: Java 8 Update 40 (? - installed 2019-09-25)
Audio Plug-ins:
    AppleTimeSyncAudioClock: 1.0 (Apple - installed 2019-09-21)
    AirPlay: 2.0 (Apple - installed 2020-05-31)
    BridgeAudioSP: 5.52 (Apple - installed 2020-05-31)
    iSightAudio: 7.7.3 (Apple - installed 2019-09-21)
    AppleAVBAudio: 760.6 (Apple - installed 2019-09-21)
    BluetoothAudioPlugIn: 6.0.14 (Apple - installed 2020-05-31)
    BlackmagicAudio: 1.0 (Blackmagic Design Inc - installed 2016-09-30)
3rd Party Preference Panes:
    Blackmagic Desktop Video (Blackmagic Design Inc - installed 2016-09-05)
    Codex (? - installed 2015-03-12)
    CUDA Preferences (NVIDIA Corporation - installed 2019-04-19)
    Flash Player (Adobe Systems, Inc. - installed 2020-04-24)
    FUSE (Benjamin Fleischer - installed 2019-12-05)
    Java (? - installed 2015-03-24)
    MagicPrefs (? - installed 2012-10-17)
    MusicManager (Google, Inc. - installed 2020-03-31)
Time Machine:
    Time Machine Not Configured!
Performance:
    System Load: 2.14 (1 min ago) 1.60 (5 min ago) 1.85 (15 min ago)
    Nominal I/O speed: 4.99 MB/s
    File system: 22.87 seconds
    Write speed: 830 MB/s
    Read speed: 1115 MB/s
CPU Usage Snapshot:
    Type Overall
    System: 7 %
    User: 5 %
    Idle: 87 %
Top Processes Snapshot by CPU:
    Process (count) CPU (Source - Location)
    AvidAppManHelper (14) 17.07 % (? - /Applications/Avid/Application Manager/AvidAppManHelper.app)
    EtreCheckPro 8.64 % (Etresoft, Inc.)
    plugin-container (9) 6.80 % (Mozilla Corporation)
    kernel_task 6.50 % (Apple)
    firefox 6.34 % (Mozilla Corporation)
Top Processes Snapshot by Memory:
    Process (count) RAM usage (Source - Location)
    AvidAppManHelper (14) 2.93 GB (? - /Applications/Avid/Application Manager/AvidAppManHelper.app)
    plugin-container (9) 2.37 GB (Mozilla Corporation)
    EtreCheckPro 684 MB (Etresoft, Inc.)
    Backup and Sync (3) 587 MB (Google, Inc.)
    Capture One 20 571 MB (? - /Applications/Capture One 20.app)
Top Processes Snapshot by Network Use:
    Process Input / Output (Source - Location)
    Dropbox 287 KB / 375 KB (Dropbox, Inc.)
    mDNSResponder 142 KB / 26 KB (Apple)
    Box 13 KB / 3 KB (Box, Inc.)
    netbiosd 8 KB / 4 KB (Apple)
    firefox 8 KB / 4 KB (Mozilla Corporation)
Top Processes Snapshot by Energy Use:
    Process (count) Energy (0-100) (Source - Location)
    AvidAppManHelper (14) 16 (? - /Applications/Avid/Application Manager/AvidAppManHelper.app)
    WhatsApp Helper (Renderer) 3 (WhatsApp Inc.)
    ReportCrash 3 (?)
    plugin-container (9) 2 (Mozilla Corporation)
    CalendarAgent 1 (Apple)
Virtual Memory Information:
    Physical RAM: 16 GB
    Free RAM: 110 MB
    Used RAM: 13.61 GB
    Cached files: 2.28 GB
    Available RAM: 2.39 GB
    Swap Used: 0 B
Software Installs (past 30 days):
    Install Date Name (Version)
    2020-05-09 ARMDC Agent Installer (1.0.0)
    2020-05-12 Adobe Flash Player (32.0.0.371)
    2020-05-14 Box (2.14.378)
    2020-05-15 Adobe Acrobat Reader DC (20.009.20063) (20.009.20063)
    2020-05-16 Security Update 2020-002 (10.14.6)
    2020-05-19 FUSE for macOS (3.10.4)
    2020-05-22 Adobe Acrobat Reader DC (20.009.20065) (20.009.20065)
    2020-05-29 XProtectPlistConfigData (2122)
    2020-05-29 Safari (13.1.1)
    2020-05-29 MRTConfigData (1.61)
    2020-05-31 Security Update 2020-003 (10.14.6)
    2020-05-31 Slack (4.6.0)
    2020-06-03 Adobe Acrobat Reader DC (20.009.20067) (20.009.20067)
Clean up:
        Executable not found
        softraidd
Diagnostics Information (past 7-30 days):
    2020-06-06 11:28:08 postgres - Crash (131 times)
        Executable: /Users/***/*/postgres
    2020-06-06 11:16:43 drserver - Crash (135 times)         Executable: /usr/local/codex/bin/drserver         Details:             dyld: launch, loading dependent libraries
    2020-06-06 11:01:04 Core Sync.app - Crash (73 times)         Executable: /Applications/Utilities/Adobe Sync/*/Core Sync.app
    2020-06-06 10:59:45 Kernel Panic (97 times)         3rd party kernel extensions:             at.obdev.nke.LittleSnitch            com.box.filesystems.osxfuse            com.codexdigital.driver.usbDockDriver            com.paceap.kext.pacesupport.snowleopard            com.sony.driver.dsccamDeviceInfo00            com.sony.driver.sxsus10drivers            com.sony.driver.sxsxqddrivers            com.sony.scsi.SR-D1
    2020-06-06 02:41:59 UpdaterStartupUtility - Crash (15 times)         Executable: /Applications/Utilities/Adobe Application Manager/*/UpdaterStartupUtility         Details:             objc_msgSend() selector name: objectForKey:
    2020-06-05 20:20:35 Backup and Sync.app - High CPU Use (6 times)         Executable: /Applications/Backup and Sync.app         Details:             objc_msgSend() selector name: updatePath:withStatus:
    2020-06-05 18:59:25 Capture One 20.app - High CPU Use (7 times)         Executable: /Applications/Capture One 20.app         Details:             objc_msgSend() selector name: isKindOfClass:
    2020-06-03 04:43:33 /Library/Logs/DiagnosticReports/drserver_2020-06-03-044333_S*****************o.crash - Crash
    2020-06-02 02:02:32 syspolicyd - High CPU Use         Executable: /usr/libexec/syspolicyd
    2020-06-01 00:09:49 Adobe Photoshop CC 2019.app - High CPU Use         Executable: /Applications/Adobe Photoshop CC 2019/Adobe Photoshop CC 2019.app
    2020-05-31 20:59:42 Finder.app - High CPU Use (2 times)         Executable: /System/Library/CoreServices/Finder.app
End of report
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
