跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Water damaged iPhone, will not move past the low battery signal.
So I water damaged my phone after using it in a pool and getting it splashed a few times. The screen went off when I was using it while it was still responding to my touch (I could turn the flash on/off). I put it in rice to suck up any moisture. It dried but the water damage indicator turned pink inside the sim tray slot. When I plugged it in to charge the display was back on and it was showing the low battery signal. I put it up to charge and it would show that it was charging. 30 mins later it was still charging (did not boot up and turn on like it normally would.) I unplugged it and tried to boot it but it would not go past the apple logo. The logo appeared, disappeared and this would continue until it would no more do it and when trying to boot it up it would display the low battery signal indicating to charge the phone. Is my battery toast? Is my logic board toast? Is a third-party service better or I should go to apple? Why would a ip68 rated phone get wet?
PS. A year ago I accidentally left my phone in rain for about 15-20 mins but it was okay. How can a a few splashes get my phone wet now? Does a phones water resistance degrade over time (I bought it in November 2018, it got wet yesterday)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You should never charge it water damaged phone. Also rice does nothing except get stuck in your charging port. The phone needs to be taken to a repair shop as soon as possible and opened up and dried out. You will probably need a new screen and it may never work correctly again. If you have the phone backed up and don't need the data I would take it to apple and trade it in. Apple will only swap out phones they won't repair them. They also won't get data off of a phone if it won't turn on. The phone starts corroding the minute it gets wet. The only way to stop it is to disconnect power. The phone says water resistant but you should keep it away from water at all times. If you are going to use it near water they have waterproof phone cases but I would still be careful. If you need data off your phone I would send it to iPad rehab ipadrehab.com they have a flat fee for data retrieval and they don't charge you if they don't get the data. If you don't need data off of it and can restore from a backup or iCloud and should trade in the phone because IF it can be brought back to life it never work right and it will have issues. It will most likely have hidden corrosion.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Agha Syed Nasir Mahmood Azeemi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 42
总计 2,701
