跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
258 个问题 查看全部
What causes these moving horizontal lines on display?
I’m assuming the issue is caused by a damaged display and that I would need to replace the display assembly to resolve the issue, but I thought I would ask about it on here to see if it might be related to something more specific. Note that the horizontal lines in the pictures are separated into 6 columns of equal width, covering the width of the display, and they are constantly jiggling around. They are mostly pink and light blue / green. The right-most column of lines is less dense. Any advice is appreciated, thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes, your display is damaged, more precisely the T-CON board has failed. This is the thin board held in the uppercase.
Most laptop displays have it within the lid. Apple decided to be different! They placed it into the uppercase in the worse location! It tends to cook!
Sadly, once damaged it is not repairable and Apple only sells the full assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide 2016 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
MacBook Pro 15" Retina (Late 2016-2017) Display Assembly图片
产品
$507.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Zachary Lunte 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 497
