跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 个问题 查看全部
MacBook Pro 15" Mid 2010 Airport card upgrade to early 2011 card?
I have a Macbook Pro 15" Unibody Mid 2010 that was dropped. I have replaced most of the parts, but I can't find an antenna for the airport card.
I have found an antenna for an Early 2011 Macbook Pro 15". In the teardown guides, all of the wireless parts look like they could be swapped out.
Does anyone know if it is possible to upgrade my Mid-2010 airport system to the newer Early-2011 airport system?
Thanks,
Chris
Update (04/21/2016)
I found an antenna on eBay. I did not choose to upgrade the card or antennas.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
Did it work?
Please let us know.
完成的
Also interested in knowing if this worked. I want to get Bluetooth 4.0 on my 2010 MBP as well.
完成的
You can. Just installed a BT LE card on mine. However it requires a few modifications. 1: cut out new holes for the plastic container or order the 2013 part. 2: connect the wifi plug to J0 and J1 (there is no cable for J3) 3: the cable that goes to the MB is a bit to long. (no fix really)
完成的
Any pictures or a walkthrough on that. I think a lot of people will want to upgrade to 4.0 to get continuity in OSX Yosemite.
完成的
continuity still not available.. Looks like a new machine is the only option if you want the new feature. This is so Apple
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
It seems like the MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board is different from the 2011 model. The connection looks like its the same but the placement is different which could cause the cable to be too short or too long.
Maybe it's worth a try? It won't be a snug fit though.
MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board图片
产品
$29.99
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board图片
产品
$42.99
这个答案有帮助吗?
得分 6
1条评论:
I have a Mid 2010 15" and am changing the logic board to a Late 2011. My BT/Wifi board is working fine. And the cable to the logic board seems to fit fine. I just wonder if I really will just work or if I have to have a 2011 BT/Wifi board. Any experience?
完成的
添加一条评论
这个答案有帮助吗?
得分 0
2条评论:
you might wanna check this post: http://forums.macrumors.com/showthread.p...
完成的
Better yet, you can use this tool if you have a BT 4/LE board in the system: Continuity Activation Tool
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 8,756
