跳转到主内容
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
30 个问题 查看全部
Why cooling fan runs and engine won't start?
My car was running normally then switched off the engine for a few hours, came back and while trying to start again, cooling fan runs, no crank and engine won't start.
All dashboard lights on after single click on start button while pushing breaks (cooling fan runs), which is really weird coz engine is not hot. Another press on start button, everything goes off.
I recently changed radiator and spark plugs + 2 ignition coil.
Any idea what could be the reason and how i can fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
We’re is the bcm I’m having the same Problem
完成的
And what all I have to tske off my part car with the same year 2007 to get this one running
完成的
Help....I am having this same issue. What did you do to fix it?
完成的
In my skoda fabia it was immobiliser. I just had to disconnect accu (battery) for 1 minute, then reconnect and engine started:)
完成的
I have the same problem but I have a '94 BMW 3 series
完成的
添加一条评论
6个答案
已选择的解决方案
It may well be that the fault with the cooling fans has drained the battery too much, when it tries to start the battery voltage collapses and the electronics give up. Try charging the battery or use a booster pack to get it started, you can then drive it somewhere to get the cooling fan problem fixed - this may well need to be a main dealer with the right diagnostics equipment.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Mine did the same and it was the engine control fuse. It's in the fuse box under the
这个答案有帮助吗?
得分 2
2条评论:
Under the what? I cant see the rest of the text
完成的
Hood I think .
完成的
添加一条评论
This usually an indication you have a shot BCM.
这个答案有帮助吗?
得分 0
1条评论:
Where ia this located?
完成的
添加一条评论
I’m have this problem now . The guy look at it he put a used relay on my van and now the same thing is happening. I’m going to buy a new relay and get the battery charged and see what happens.
这个答案有帮助吗?
得分 0
1条评论:
Did you find out what it was?
完成的
添加一条评论
It might be immobiliser. I disconnected battery for 1 min, reconnected it and the car started
这个答案有帮助吗?
得分 0
添加一条评论
Anyone know why the headlights, blower motor and turn signals are all on at once without the car started?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ahmad Nawar 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 154
过去 30 天: 668
总计 17,706
