跳转到主内容
A Sony Cyber-Shot DSC-W120 is the 2008 entry of Sony's DSC-W series digicams. Comes with a 2.5" LCD screen and a disappointingly small viewfinder.
8 个问题 查看全部
Is there a way to fix water damage?
My daughter had her camera in her backpack and her water bottle popped open and got everything wet. It wouldnt tun on after that. This was a couple years ago, and it still wont. She said it didnt get very wet so I thought it would dry out and be ok. Is there anything I can do to find and repair it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
but my cam not fix still i opened and saw it some damage in motherboard like sky blue how to fix it please help me
完成的
添加一条评论
2个答案
已选择的解决方案
My concern at this time would be corrosion. Hoe you removed the battery. Make sure the contacts have not corroded. You could follow the teardown from here to disassemble your camera. For any liquid immersion, I would suggest this guide. Hope this helps, good luck.
这个答案有帮助吗?
得分 6
添加一条评论
Dropped the camera out of my hand on the ground and when they run did not operate how repaired
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shanda 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 6,854
