跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
iPhone 4 Verizon dock connector differences between white and black
I have a white 32gb verizon iphone 4. One of the pins on the dock connector looks burned. Everything still works, but I cannot sync the device. I want to replace the dock connector. Do you have replacement parts for the white iphone? Are the dock connectors on the black and white the same? I know the color is different because my dock connector is white.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Since the burn damage may have damaged the logicboard, I'd inspect that before you spend too much money on the phone. If you find out the problem is isolated to the connector and the board survived, then there should be no problem with just replacing the connector.
If the motherboard didn't survive, you're probably better off getting a new phone. New boards are very expensive and used boards are a gamble in terms of usability; this isn't a problem with a new phone.
While it is possible to do a bare replacement with solder, it's a difficult thing to do. The connector is inexpensive so it really isn't worth the effort (or gamble) to reuse the old assembly. Even then, this is an advanced soldering job.
iPhone 4 Verizon Dock Connector Replacement
iPhone 4 Verizon Logic Board Replacement
iPhone 4 Verizon Dock Connector图片
指南
难度:
中等
iPhone 4 Verizon Logic Board图片
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 2
1条评论:
I just ordered the complete dock connector. Hopefully I will be able to use the "installing iphone 4 verizon dock connector guide." I doesn't look like I will have to solder anything. On a side note: The burn on the connector looks like it is coming from pin 15 or 16. Those are usb ground and main ground. I am able to connect my phone to my computer and view the pictures, but the itunes cannot reconize the phone. If I use "ifunbox" to view the iphone, it says it is not able to initialize mobile apple service. I will update when I get a chance to do the swap.
完成的
添加一条评论
添加你的答案
yang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,665
