跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
401 个问题 查看全部
Why is my new screen unresponsive?
Ok this is quite obscure and is definitely racking my brain.
I have a XR that I wanted to replace the screen on. I bought a donor phone that has a good condition original screen. When testing this donor screen on the phone it came on it works well and touch responsiveness is perfect.
However, after transferring this screen to the phone I want to fix the entire top half of the screen is completely unresponsive to touch. I reseated the connection multiple times but always the same issue.
When I transfer the screen back to the donor phone it works perfectly again.
This made me believe it might be an issue with the phone I want to fix and so I put the original cracked screen back on but the response on it is completely normal again.
Therefore I am completely puzzled as to what is causing this. It’s like two working things come together to make a broken thing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
If anyone ever has this problem: Turns out XR screens are produced by different manufacturers LG and Sharp and the screen are not compatible on certain XR’s I guess. I was lucky in that my own XR had a screen that was compatible with the phone. And the donor screen was compatible with my phone. So I just swapped them.
这个答案有帮助吗?
得分 0
添加一条评论
Get a magnifying glass and check the connectors on the phone and the screen. Then clean the connectors with a qtip and alcohol and a soft brush. Make surge connections seated. Did you try the cracked screen on the donor phone to see if it works on it?
这个答案有帮助吗?
得分 0
1条评论:
Yeah this wasn’t it. Turns out XR screens are produced by different manufacturers LG and Sharp and the screen are not compatible on certain phones. I was lucky in that my own XR had a screen that was compatible with the phone. And the donor screen was compatible with my phone.
完成的
添加一条评论
添加你的答案
Simon Knopf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 876
