跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
145 个问题 查看全部
Press home to upgrade, but my home button is not working.
Hi guys.
This is my situation. First, I fix LCD screen on my self.
while doing repair, I unfortunately tear the home button(Touch ID) cable.
My LCD is perfectly repaired but home button is not working. so I was using assist touch instead of home button. (it was fine)
But After make IOS updates,
Press home to update make me crazy.
assist touch is not appeared.
I already connect to my Mac with cable, but didn’t recognize it.
and I already connect with to pc iTunes but didn’t recognize, too.
Are there any other way to skip the ‘press’ the home button or fix it?
Plz somebody help me…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
i have a solution. when iTunes finish updating your software, it will prompt you to keep the phone plugged with USB, but you have to unplugg it and turn your iphone on again and than connect it to itunes and manage as a new iPhone.
完成的
添加一条评论
2个答案
已选择的解决方案
You should be able to replace the button although you’ll lost touchID. You also might be able to send it to a microsoldering specialist that can fix the original home button.
这个答案有帮助吗?
得分 0
1条评论:
Yes, you are right..
完成的
添加一条评论
最有帮助的答案
There is a way to unlock an iDevice running iOS that has a broken home button and no access to Assistive Touch. Try the following:
  1. On your Lock Screen, swipe right.
  2. You should see the Search field at the top.
  3. Type Settings in the Search field.
  4. Your 'top hit' should be the Settings app. Tap on this.
  5. You should now get the Touch ID or Enter Passcode screen.
  6. Enter your passcode.
  7. You should now see your settings.
  8. Go to General -> Accessibility -> Assistive Touch and turn it on.
  9. Also, while your still in the Accessibility settings, scroll to and tap the Home Button setting
  10. Change the Click Speed and/or Rest Finger to Open settings to see if that also helps.
Good luck!
这个答案有帮助吗?
得分 2
1条评论:
I like your answer better than mine! How do we switch yours to the best answer?
完成的
添加一条评论
添加你的答案
kyungbum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 1,609
