跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
6s plus to dfu mode
can you please explain in more simple words how i can put iphone 6s plus to dfu mode if home button doesn't work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try 3utools. It’s free and it should allow you to put into DFU mode without the home button
这个答案有帮助吗?
得分 0
3条评论:
i am using 3utools but it can but iphone in recovery mode only
完成的
@tameer do you know why the home button isn't working?
完成的
I am not professional enough i tried to check if it is original or not and i cut the home button cable check the pictures plz
完成的
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
1条评论:
If you read my previous comment, the one I just deleted, I made a mistake. I took a better look at the second pic and noticed it was a 6s plus my bad. You'll have to replace the screen to repair that cable and hopefully restore the home button. If the button is damaged, you can buy a new one but you'll lose TouchID.
完成的
添加一条评论
添加你的答案
tamer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 248
