跳转到主内容
A security and intelligent doorbell that live streams 24/7 and notifies you if someone is at your door.
5 个问题 查看全部
not working Nest Hello
two devices were installed and working then after two weeks not working and not even a light .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If your situation is similar to mine, I had a power cut (power outage) that happened when the outdoor temperature was below freezing. As a result my Nest Hello (Gen 1) wired doorbell never rebooted when power was restored. Solution: Disconnect it, bring it inside, power it up on USB (leave it alone for about 30 minutes to heatback up to room-temperature). Then reinstall it (quickly) while back outside. It's now happily wired-back and online.
这个答案有帮助吗?
得分 1
1条评论:
This is confusing - a wired doorbell has to be charged/powered up on USB? Why even bother with a wired power connection then?
完成的
添加一条评论
添加你的答案
Malbrahim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 289
