型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
226 个问题 查看全部
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
7个回答
最有帮助的答案
Sounds like replacing the battery would solve the problem.
这个答案有帮助吗?
按维修分数 3
添加一条评论
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
这个答案有帮助吗?
按维修分数 0
添加一条评论
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
这个答案有帮助吗?
按维修分数 0
评论:
please start a new post- just ask a question :)
添加一条评论
Have you tried a soft reset first to get back to the startup screen?
这个答案有帮助吗?
按维修分数 0
添加一条评论
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
这个答案有帮助吗?
按维修分数 0
添加一条评论
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
这个答案有帮助吗?
按维修分数 0
添加一条评论
tell me what i cant do
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
cindy 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 3,107
