跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
My MacBook died after I plug my power cord
My macbook suddenly died as soon as i plug my power cord with 30% battery. I tried to reset but did not work at all. Im not sure if it makes sense because i am in Philippines and power voltage is different . Might be short circuited? Please help. Im losing it and its covid lockdown. :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hope you figured it out but if not - your Mac most probably alive.
No the difference in the voltage should not do any harm unless it delivered in spikes of enormous amplitude which should be rare even in Philippines
Could you please precise with what key combo have you tried to restart?
Have you tried Control+Option+Shift+Power button?
If not - try it.
Same key combo as for SMC reset but one quick press.
If it is up and running - great. If not - try to do SMC and PRAM reset and see what’s happening. Normally it should fix your A1708.
If not - I would first check the power supply module whether it is working with something else.
If it is working and your Macbook Pro still show no signs of life then the deeper investigation will be necessary.
Let’s hope it will not be that serious.
Please post your findings and we will proceed from those.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Victoria 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 31
