跳转到主内容
Laptop manufactured by Asus, running on Google Chromebook OS. Released June of 2014.
17 个问题 查看全部
laptop will not start.battery&power light blinks but no turn on
all thats happening is power light on top right flashes. and orange battery light goes on when we plug it in. sceen stay inactive, nothing…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
The power light of an ASUS Chromebook C300M flashes when the computer is in “Sleep Mode.” The orange light indicates that your battery is charging, but the power is low.
Please allow the Chromebook to finish charging; it may take a while if the battery is low.
Try holding down the power button for 10 seconds or until the power light stops flashing. Then close the lid, reopen it, and turn it back on. That may help get it out of “Sleep Mode.”
这个答案有帮助吗?
得分 3
6条评论:
Ok I tried this but it just goes back to blinking, it’s at full charge but just won’t turn on, I only got the laptop about 4 months ago
完成的
If rebooting didn't work, try a hard reset. First, turn off your Chromebook. Then press and hold the Refresh button (it looks like a circular arrow). Then tap the power button. Only release the Refresh button when the Chromebook boots up.
完成的
This worked. Thank you!!
完成的
@dancomptia Hard Reset for the win on ASUS Chromebook C423N
完成的
Lenovo Chromebook C330: The first one works, thank you!
完成的
显示更多的1条评论
添加一条评论
As you said "Power button flashes once when pushed, but no fan spin"
My guess is your laptop isn't getting the right electricity, it might be your power supply problem.
You need to go to a service point.
这个答案有帮助吗?
得分 0
1条评论:
Did you ever figure out what was wrong or get this fixed?
完成的
添加一条评论
添加你的答案
epifanio zamora maravilla 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 13,322
