Internal Microphone isn't registering any sound.
I upgraded my NVMe and HDD last night. This morning, everything works EXCEPT my microphone. Obviously, there is a chance that I did not connect the microphone cable, but I’m 99.4% positive I did. Any chance someone can tell me where on the logic board the internal microphone connection is? Thanks to any/everyone who helps in advance!
Update (05/06/2020)
So, I tore it back open....and yes...I did not connect the microphone connector all the way...it was a bit loose. So I popped it back on and called the wife over FaceTime audio...and it worked PEREFECTLY! Once I buttoned it back up and powered it on...it stopped working...but not completely. It now will register sound if I tap on the Apple logo or anywhere on the case itself...but it won't register voices...I'm a little stumped here. I'm going to open it back up on the 12th...when my new adhesive strips get here...any input will be greatly appreciated.
1条评论
I have two 2019 iMac 27" iMacs and upgraded both their hard drives to SSD's. So much faster. But curiously, BOTH have this exact same problem. The microphone is registered. If you tap the top of the screen, volume apps pick up the 'thud.' But otherwise, it does't pick up voices. Maybe the screen cutter nicked a cable?
由 charlie 完成的
