跳转到主内容
Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
99 个问题 查看全部
Charging keeps going on and off
I have not seen this issue before. When plugging into the AC adapter the charging icon keeps going on and off. I hooked it up to a known good Apple adapter and and getting the same results. We don’t seem to have a guide on this model. I have hopes that this may be the I/O board and I can just replace it.. But I don’t have a part number past the 2015 model. I did manage to download and run Coconut Battery and it shows about 76 cycles but also shows it going on and off. I have not seen this issue doing a web search. Was hoping someone may have seen this also.
@danj
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
@mayer - Sorry guy I haven't even opened one up yet! I doubt I will for quite awhile.
完成的
@danj This is my first one, I don't usually see them for several years. I did get it to shut down and it has charged to 60% in a short period of time but as soon as I booted it up the on/off stuff started again. Of course it has a couple Thunder ports
Part # 821-01658
完成的
添加一条评论
1个答案
已选择的解决方案
Replacing the damaged Thunderbolt I/O board solved this problem
Contrary to the zippy teardown iFixit did on this model, the bottom case does not come off the way the earlier models did. It had two inserts that go directly in to recepticals. Trying to slide it horizontally could shear these pins off. It just pulls straight up. When replacing the bottom case, you simply press down on those two spots to click it back in place. I took a couple of photos while doing this repair and will try to remember to post those on a semi-guide. To replace the I/O board you do have to remove the five screws that hold the logic board in place and lift the board slightly to have the room to remove and repave the board. You do not have to take the board out or remove any of the connectors. The board has two P2 screws on the inserts (chrome colored) and two black T5 screws holding the board down.The battery to logic board connector simply slides out horizontally.
这个答案有帮助吗?
得分 3
2条评论:
Good catch @mayer !!
Was there more liquid damage besides the ports?
完成的
@danj I found no more internal liquid damage, however the bottom had a hard case on it and the goo had spread around to all the edges.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 27
过去 30 天: 100
总计 12,249
