How to test power button / keyboard?
Is there a way to power this on without keyboard, similar to what is possibly on older macbooks by shorting two connectors on the Logic board?
Mine suffered a liquid spill and now will not turn on. I cleaned corrosion, etc from logic board, but still will not turn on.
Logic board could be bad, but want to rule out keyboard/power switch first.
Update:
Tried dishwashering the upper case, but no difference
3条评论
Thanks RJ. Somehow when I searched I think I must have thought that one was talking about the 1181 instead of the 1342, when it was the other way around...
Anyway, thanks for the link.
由 dczech 完成的
Still no luck with this 1342, but I did notice that the power cord flashed the green LED briefly when I first connected it, then flashed orange several times, then remained dark... not sure what that could indicate, so about to do some research.
由 dczech 完成的
HMMM, cleaned the magsafe port on the 1342, then connected power to it, green light lit steady for about 2 minutes, then slowly faded to black, probably about 25 seconds to fade... disconnect and reconnect and it stayed black.
Weirder and weirder. (at least to me)
由 dczech 完成的
