跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87 个问题 查看全部
Lid making grinding noise when I close it
Hello,
I have some sort of an issue with my MacBook pro 2019. Whenever I open the lid above 90 degrees, and when I close it, it makes kind of a grind noise as something is touching inside between the lid and the antenna.
https://youtu.be/Ra6F_XZVqMg
This is the noise that is making.
What is your opinion about this stuff? Did you seen or heard anything like this?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Did you bang the system or have something sit on it?
Something is bent or out of alignment!
完成的
No, it,s just out of the box brand new, no hits . Everything seems ok with it execept with this thing. I will try to remove the back cover to see whats up but i can't find a pentalobe screw
完成的
添加一条评论
2个答案
No! Don’t mess with it! Time to visit an Apple Store for them to fix it.
这个答案有帮助吗?
得分 0
1条评论:
To late haha . i ve opened it it s the plastic cover of the display rubbin a bit on the antena. Dunno why… but i believe it s not so much big of a deal… i live in Romania… here is a bit hard to find a good apple service unfortunatley :(
完成的
添加一条评论
As it is an Apple product, I would advise you to take it carefully from here.
Shake the laptop mildly and notice if something is loose inside it.
If there is no such thing then don’t open it. Take it to the Apple service center.
I hope this helps!
这个答案有帮助吗?
得分 0
2条评论:
Yes when I shake it with the lid closed it s a slight noise coming from the inside.with the lid opened no noise...
完成的
Any ideas? The interior looks fine
完成的
添加一条评论
添加你的答案
cvld88 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 445
