跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Why won't my Switch Charge?
So my girlfriend recently purchased a Nintendo Switch online and I cannot figure out for the life of me why it won’t charge. Things I have tried are:
  • Replacing the Battery (Successfully, showed charged, but won’t recharge even with new battery).
  • Testing multiple USB-C cables, an off-brand, and an on-brand.
  • The console indicates that it’s charging but the number just falls to depletion.
  • When connected to the dock, it doesn’t make any difference and does show on the screen as it would on the tablet part.
My question is the fact that I have occurred the forums and tried everything but replacing the USB-C or any of the on circuit chips. Should I try replacing the USB-C connector? Since it is indicating that it is charging, but not actually charging means its more of a chip issue? Are most of the chips repaired with a heat gun?
Thank you in advance for all of your help/suggestions!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
chips are replaced with a hot air station and soldering iron, if you have a multimeter check the fuse above the port. also if you have never done repairs like this before i would suggest taking it somewhere that repairs them as you could cause more damage
这个答案有帮助吗?
得分 1
添加一条评论
Check inside the charge port with light and magnification for damaged pins. Have a shop replace the charge port unless your confident with using a hot air station.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jordan Viehmeyer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 161
