跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
unable to activate sim card?
“my iphone does not activate my sim despite it being locked to same carrier, i called the carrier, and they say they are unable to activate it for me, i checked imei pro and it says the iphone is clean, i dont understand what the problem is can someone please help me ?”
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
What carrier are you using?
完成的
Freedom mobile 41.0 and my sim is freedom
完成的
添加一条评论
4个答案
I had a nearly identical issue with an iPhone 6 model. Have you tried to activate it over WiFi? Or is that also causing issues?
这个答案有帮助吗?
得分 0
添加一条评论
yes i just insert the card, and activate it over wifi, because i think wifi is already active when i try inserting the sim, after i keep getting a message that says unable to activate sim card , so you suggest trying to insert the sim while not connected to wifi, or ?
这个答案有帮助吗?
得分 0
2条评论:
and yeah my phone is an iphone 6s plus
完成的
Best to get a GSX report on your phone
完成的
添加一条评论
How can it be activated? Change the i fix to signal of smart
这个答案有帮助吗?
得分 0
1条评论:
Please let me have cignal
完成的
添加一条评论
How can i have the signal of my simcard?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muhammad T 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
