跳转到主内容
Model M8407 / 550 or 667 MHz G4 processor
28 个问题 查看全部
My hinge is super stiff on my TiBook G4 Onyx
Hello, I am new to the forums. I have an old TiBook G4 that I started using again after years of sitting in my closet. I used to use it a ton about 8 years ago I never remembered the hinge being that tight. Is there an easy fix, or do I need to do more extensive repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Carefully taking off the hinge covers (2 screws each) you can gain access the the hinge screws loosen them to see if the alignment is just off, retighten if not better you’ll need a cotton swab and some WD40 carefully spray the WD40 into the red cap to make a small puddle. dip the cotton swab into it (not too much!) and wipe the exposed clutch spring move the lid a few times and try a bit more oil it doesn’t take much!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ClassiMacYT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 109
