跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Won't charge when is turned on
I have a costumer iPad and it won’t charge, i have changed the charging port but still the same problem, after i removed the shield and started to measure the components with multimeter I noticed some condensators are shorted to groud, but i can't identify the net because i don't have schemes for it. The shortened condensators are near the PMIC between the coils, none of them are cracked or damaged and the iPad don't heat. If someone has an idea what to do i would appreciate. Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I forget to mention that if the battery is dead the iPad charge the battery until it powered on that it stops
完成的
添加一条评论
1个答案
已选择的解决方案
The problem was PMIC failure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adrian Zymeri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
