How do I remove condensation between the touch panel and the LCD?
An area of condensation has formed along the upper left side of the touchscreen of the phone, rendering the device virtually unusable for anything accept for what can be done with voice commands.
There isn't any visible moisture in the device and it hasn't been dropped into liquid. The phone was left in the car, in the sun, but that seemed to make the spot bigger.
I've tried leaving silica gel packets in the battery compartment when not using the phone, and also leaving the device in a sealed container of dry rice in an attempt to draw out the moisture without success.
2条评论
@oldturkey03, Thank you for your answer.
I found the service manual to be very helpful except for the separation of the touch panel from the frame. Apparently, there is a thin plastic between the touch panel and the LCD, and that is where the moisture is. The touch panel appears to be very securely glued into place and I'm not equipped at this time to try to loosen it. I am happy to report that there is no other indication of moisture damage.
由 David R Thurber 完成的
Excellent and I hope you get it back in shape....good luck.
由 oldturkey03 完成的
