MB 200 LCD replacement same as Droid?
The LCD screen on my wife's Motorola MB200 is badly scratched and she want's it replaced. Can I use the guide for the Droid as a similar goby for the MB200?
I own an MB200(dext is the European model) if you look at your phone and the screen is scratched and there are no crack that seem to be under the glass.. than you need to Replace the Digitizer... I replaced mine when it went haywire on me was dialing numbers on it's own, etc. basically living its own life
by replacing it myself i saved about $60 but its as much as hard as its time consuming.
The LCD and the Digitizer are two separate components.
这个答案有帮助吗?
Becarefull when disassembling the mb200 it has much screws and alot of its parts glued w/3m double sided tape. including the digitizer.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 923
