跳转到主内容
Bright flat panel circular LED ceiling light
4 个问题 查看全部
Intermittent fail to switch on LED panel light - RESOLVED
After a couple of years user found this light would not come on. Checked OK, eventually found yes it is faulty, not before replacing the power adapter to no avail. Took it apart and found the fault.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I have repaired 3 LED’s recently, Dismantle the unit to expose the individual LED’s, check each LED to find the faulty one, most times it is obvious to the naked eye, remove the individual faulty LED and jumper across it with a blob of solder or a jumper wire.
As each LED is connected in series, just like the old Xmas tree lights, when one expires, they all go out.
LED’s can handle a range of voltages so a small increase to the rest by removing one shouldn’t bother it.
If you’re at all concerned, test run it on the bench for a day or two as I did, no extra heat, all are back in place and have been going for months.
这个答案有帮助吗?
得分 1
1条评论:
In fact the LED power adaptors are constant-current, not fixed voltage, so shorting round an led element will not over-stress the others. As happens when you stuff metal foil in the socket of a missing Christmas tree string . .
完成的
添加一条评论
Undo the six screws holding the back panel, remove card disc, and two light reflecting discs. LEDs are a circular tape inside metal frame, in two lengths, and solder blob connecting them appeared dry or broken. Repaired by soldering a bit of wire. Moral: don’t order a new power adapter till the luminare itself is checked!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David McGovern 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 35
总计 418
