跳转到主内容
Repair guide for Philips Respironics V200 Esprit ventilator. This guide can help biomedical technicians find repair solutions for this equipment.
1 个问题 查看全部
How can I fix 'trending not available'notification on display?
Any time the ventilator is turned on it says ‘trending not available see the operator manual’ and some of the front panel button are not functional including alarm. According to operator manual,I checked the PCMCIA card and it seems to be  ok.so what should I do?It is Philips V200 ventilator
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
This appears to be an optional feature—I wonder if there's a way to disable it. I looked through the service manual: Repironics Esprit Ventilator Repair and couldn't find anything specific. Asking a friend who has experience with these Philips models.
完成的
添加一条评论
2个答案
Here is pages from the Ops Manual for the Vent:
Philips Respironics V200 User .pdf
Chapter 13 (Pages 13-78 to 13-81)
The Trending Not Available message indicates a problem with Trending option data storage
This message may appear if:
•the PCMCIA card installed for the Trending option is removed,
•the PCMCIA card includes unrecognizable or corrupted files, or •the PCMCIA card does not contain enough memory.
•the internal clock setting was moved back by more than 1.25 hours and trending data was not erased.Contact Respironics Technical Support for more information.
Specifications
WARNING:The cover plate for the PCMCIA slot at the back of the ventilator must be replaced after the adapter and card are installed. This is to protect the ventilator.
CAUTION:The PCMCIA card should only be removed by trained service personnel once power to the ventilator is off.
Data collection and display. The system collects numeric data every 20 seconds.
Alarms are considered active if they occurred at any time during the previous 20-second interval.
If the selected time scale is 2 hours, each data point on a waveform represents 20 seconds.
As the scale is increased, each data point represents a longer interval.Data is periodically refreshed if there is no user interaction.Display time-outsThe Trending screen automatically reverts to the Monitor screen if 15 minutes elapse without user interaction.
Pop-up windows are cleared from the display if 2 minutes elapse without user interaction, and any pending changes are cancelled.
Table 13-12:  Trending Data Specifications  (Sheet 1 of 4) Page 13-81.
If you did all of that, then need to check interconnecting cables inside the vent to the front panel. It could also be the front panel or its interface.
Good Luck
这个答案有帮助吗?
得分 0
添加一条评论
It doesn’t seem that info is very intuitive. The problem is your ventilator was previously interfaced with a physiological monitor, and is either looking for vitals from, or trying to send vitals to this monitor. If you call me I may be able to walk you through it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lydia 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 11
总计 204
