跳转到主内容
The Magnavox MDV2300 is a progressive scan-capable DVD player.
3 个问题 查看全部
DVD disc don't play
I bought a brand new DVD to play in my old DVD player it started Make a lot of noises n started to skip scenes n freeze, i cleaned the laser and put the the DVD back in player stilk the same result play good all the way to the end of movie n then started skipping n freezing so threw the old player away. Bought a new DVD player n now put the same DVD disc on and starts off with the opening scripts then goes directly to halfway to the movie then goes to 1/4 way to the end then goes to the begining n then back to the end then halfway then goes to end credits it's like all the scenes are jumbled up now I've tried other discs that I played in my old DVD player and those discs play just fine confused why this only DVD does that
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @firehelitacker ,
Not working correctly on two players makes it appear as though the new DVD disc is faulty.
Have you checked the surface of the new disc to ensure that there are no scratches and that it is clean etc, you didn't say?
The 3rd post down (Admin’s 1st post) in this link may be of some help determining if the disc itself may be the problem. See the section in the post starting with “On really crappy DVD recordable media,…..”
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 319
