Is the mylar reflector needed?
So the mylar reflector didnt hold up to being removed when changing out the battery. Does it have to be there? What purpose does it serve? Trying to decide if I need to find a suitable replacement for it.
It is a good thing to have in there. Basically, it reflects light from the backlight out toward the LCD and away from the inside of the iPod. Additionally, it'll give the display a uniform appearance when you look at it in direct sunlight. If that mylar isn't in there, you'll see some cutouts and screw holes on the metal midplane as the LCD and its backlight are pretty transparent when viewed in a bright enough light.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,038
1条评论
Are you talking about the tape that covers the battery solders?
由 Phillip Takahashi 完成的
