跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Earpiece sound distorted and too loud after screen replacement
My earpiece during calls is too loud even at the lowest volume setting. It's so loud that it even distorts the sound of the other party speaking.
I replaced my iPhone 4 display twice and disassembled it several times more to fix stuff I have overlooked due to my lack of experience.
Now, that earpiece problem appeared after the second display replacement.
I changed several firmware versions inbetween the assemble/disassemble games so I'm not excluding a software issue as well, but I was wondering if there's a possible hardware reason for that - something I messed up when I was assembling it back.
Thanks for your input.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Are all connectors attached properly? The connector(s) may disconnect when re-assebling. The connector(s) might also be dirty.
这个答案有帮助吗?
得分 0
3条评论:
Could it be the connectors to blame? I mean... it's not that I'm losing some of the sound, it's just too loud causing the earpiece to crackle right form the FIRST volume bar.
完成的
Perhaps I hevn;t lodged the earpiece correctly, I just found this on the Apple forums:
"I took mine to a genius bar and they replaced the handset as they said the earpiece was evidently defective and loose in its housing causing distortions."
完成的
Perhaps it is the connectors. check the connector again to see if the problem is still precent.
完成的
添加一条评论
hi.. i have the same problem.. i have awful sound with my earphone after replacement my screen.. bass sounds are disorted.. did you fix yours? i will be happy if you share your solve..
thanx..
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,841
