跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
898 个问题 查看全部
320 Gb HDD from Toshiba
iPod Classic (new one) will accept Toshiba 320 Gb HDD?
What about this: http://www.amazon.com/Apple-iPod-classic...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
评论:
need more information on the 320GB. What is the drive number? What is the interface....your ipod is a 6th gen classic?
完成的
完成的
If your question is if this one will accept the above drive, then the answer is no. Same problem.
完成的
Thank you verry much.
完成的
You are welcome, good Luck
完成的
添加一条评论
2个回答
已选择的解决方案
If you are thinking about using the Toshiba MK3233GSG in your ipod, then the answer is no. It will not work because it has SATA interface. The 320GB is a dual-platter one, that means that the interface wont fit and it has different mechanics as well . The HDD for the 160GB iPod is 5mm thick and the 320 GB is 8mm. Hope this makes sense. Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
There is a 250GB drive out there with an ZIF - IDE Interface. As far as i remember they tested it in a 5.5G iPod Video and it worked.
这个答案有帮助吗?
得分 1
评论:
Thanks you :)
完成的
添加一条评论
添加你的答案
Ted 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,347
