No service engine soon light at all.
Service engine soon light is not coming on during test cycle? Is there a fuse for this light?
Tiny dashboard lights don’t typically have their own fuses since they are fed from other sources such as the ECU on modern cars. I would attempt to check the bulb and see if it has failed. You need a full wiring diagram for your vehicle if you want to solve this. A good dealership tech is probably going to give you better advice than you can likely find here. Reading the codes from the ECU might tell you what is wrong easily.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 349
