跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
Laser Engraving?
I'm not sure if this is the place to ask this, but I want to engrave a design on the back of my iPhone and was wondering if anyone else has done this. I've found information about the specific laser settings required to engrave the original iPhone but I've found nothing about the iPhone 3G or 3G S.
If I can't find that information I was wondering if someone has a dead iPhone 3G or 3G S with an in tact back shell I could have to test the strength (I just want to engrave the shell, not the circuits below it :D). I bought a replacement shell from a site online but it is clearly a different material making it rather useless for testing.
Thanks for the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
I have taken Electronics as a subject for 4 years and I am currently taking it for GCSE. We always house circuits in plastic cases and these are either vacuum moulded or laser cut. The laser cutter is perfectly safe for cutting plastic provided it has a ventilation device, which is really should. In the program we use, Black lines engrave on the surface of the plastic, red lines cut through and blue lines rasta. I have laser cut on Acrylic and Formex.
Also, Apple provide a laser engraving service for iPod or iPhone on purchase. You only get a few lines of text but it shows it can be done.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I would say start with the lowest intensity setting then keep going over it if it's not enough. Of course, that would mean you'd have to leave it in place so not to adjust the alignment in the engraving devise. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
I think it'd be a bad idea, burning metal is one thing, that's supposed to work, but plastic is another. Burning plastic can give off noxious chemicals which while they may not be damaging to you in small quantities, they can be to your phone. You also weaken the back of the phone, and the engraving would not be like metal, so you could easily get more scratches and CRACKS, in their. Bad idea if you ask me.
这个答案有帮助吗?
得分 1
2条评论:
I disagree, as I explain in my answer
完成的
I agree with you
完成的
添加一条评论
check out http://www.adafruit.com/laser/
they also have forums.
the basic gist is that laser etching plastic is ok, be wary of chemicals and don't etch anything white as you tend to get an ugly burned brown color as opposed to a clean line.
a black iphone should be okay though.
hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
We engrave plastics all the time and iphone's engrave extremely well on a CO2 laser - as drock has said engrave on the lowest power and highest speed to avoid burning the item and then run over the iphone again if the engraving is too feint.
We mainly engrave wedding gifts such as glass and crystal in our business but iphone engraving is very popular.
Regards
andy
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,929
