跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
553 个问题 查看全部
Lawn mower won't move forward or backward, running out of options
Hey everyone,
I have a Craftsman LTS 1500 I’m trying to fix.
It came with the house my friend bought, wasn’t running (except for a jump start) and I was in the mood for a little project anyway.
So I got the engine to run, replaced the battery, replaced the spark plug, did an oil change and added fresh fuel.
It ran for a little bit and after taking it for a spin, nearing the end of mowing the lawn it stopped moving.
The engine still runs and it fires up great, however it won’t move when I put it in gear, and the engine dies whenever I release the clutch.
My first instinct was the drive belt, it looked a little worn so I replaced it.. nothing. After that I figured it could be the pulley, which also looked worn and too smooth to provide any grip for the belt and so I replaced that too.. again nothing.
Couldn’t find anything on YouTube on this issue so figured I’d try here.
I’m not that experienced with engines, but I’m willing to learn, and this little lawnmower seemed like a good place to start.
This is about the extent of my knowledge, so I’d really appreciate any advice.
Thanks a lot!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
7个答案
最有帮助的答案
Check the blades on the bottom and check for any clots…grass clots pathways and can stop the blades… I also might be the rotary chains on the inside….(gear chains..)
这个答案有帮助吗?
得分 1
14条评论:
You could also try pushing it... :) :)
完成的
I cleared all the blades, and the blades are still currently off the tractor. It should just move without the blades on right? Didn't check the gear chains, and not sure how I would do that?
完成的
@communist_geek haha, yeah.. not gonna happen lol
完成的
you would need to take of the blades and then get a bright light. There are some bolts holding the protector on... take them off.... the chain should be right there....
完成的
Craftsman 54 inch mower deck belt diagram - Robin Hood Rx
copy and paste this into your browser...
完成的
显示更多的9条评论
添加一条评论
If your engine dies when releasing clutch you have a safety witch that is either going bad or is bad. Test switches and see where that gets you. But for it not to move forward or backeards you should lookin to your transmission
Update (03/18/2021)
So does it have a hydrostatic transmission?? If so change the fluid. And not with regular tranny fluid. Has to be hydrostatic fluid. Let me know please.
这个答案有帮助吗?
得分 0
3条评论:
Let.me.kkow.if you need more assistance
完成的
When my neighbor sat on the mower and engaged the deck. It mowed beautifully. So when I tried the mower slowed down and won't go forward. So the neighbor sat on the mower without engaging the deck and drove it fine. What could be the problem
完成的
My weight is almost 300 pounds. His weight is 180
完成的
添加一条评论
I have the same mower. Mines did that too so I took it to the shop. The mower is overheating. Its is black hard plastic thing up under the back of the mower. See my mower would run great and then all of a sudden stop. Wouldn’t go forward or backwards. Shut it off for 5 minutes and the mower goes right back to cutting and then it’ll happen again. Your mower is just overheating the engine
这个答案有帮助吗?
得分 0
添加一条评论
My husband is a small engine repair man he wants to know if it rolls when you push it if it does check where your release arm is to see if its releasing like it should
这个答案有帮助吗?
得分 0
添加一条评论
Safety switch on clutch mafunction
这个答案有帮助吗?
得分 0
添加一条评论
Sounds to me like the valves are out of adjustment or the coils are bad, try wrapping the plug wires with black electric tape, if it runs it will last a bit
这个答案有帮助吗?
得分 0
1条评论:
Was going back over grass I'd already mowed. Hydrostatic clutch/brake pedal suddenly came all the way back towards back of mower and stopped moving forward or backwards. You can push pedal in and when you let go, it springs back like a springs pulling it back. Never done it before. It's an older but well maintained Husqvarna 54 in. cut, 26hp, garden tractor. I've checked everything and I can't find anything. Spring is connected brake rod intact etc?????
完成的
添加一条评论
Belt popped off mine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marty 将永远感激不已
浏览统计数据:
过去 24 小时: 46
过去 7 天: 293
过去 30 天: 1,012
总计 7,371
