跳转到主内容
Won't run off power adapter, but charging light is orange?
My iBook sat for a few months and completely drained the battery. It won't turn on, regardless if it is plugged in. No power/lights/signs of life.
I bought a new battery that came with a half-charge, and the computer will boot-up normally with that installed.
The power adapter light is always orange, even if there is no battery in the computer. The battery does not get charged, nor does the OS show that it is getting charged.
Based upon research, I suspect it is the power adapter, except that the light is orange. The diagnosing steps state that the charging light stays green if it is a bad power adapter.
Thanks for your help.
-Cory
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Use a multimeter to test the output of the adapter. Check the tip of the adapter to see if it is broken. This may be the adapter or the DC-IN board. Download and run Coconut battery to see what you are getting. Let us know your results of both tests.
http://www.coconut-flavour.com/
这个答案有帮助吗?
得分 2
2条评论:
I'm not sure exactly how to test the adapter, and whether I'm testing Voltage, Amperage or Resistance. The center pole as 3 separate conductors, and the outer ring, which makes 4 probe points.
Assuming you're suggesting I test Voltage (while the adapter is not plugged into the computer), if I probe the bottom conductor on the center pole and probe the outside ring, the charge light goes Green and reads ~21 V.
I'm not able to make any other combination of probes read any results.
Regarding CoconutBattery, I'm still on 10.3.9, which doesn't appear to have a compatible version of CoconutBattery available. Is there another app I should try, or can you tell me what specific result you're looking for, that I could find in another app?
Thanks Mayer for your help.
-Cory
完成的
UPDATE - here's the pinout, it should be at 24 volts: http://pinouts.ru/Power/apple_tibookpowe...
完成的
添加一条评论
I was able to borrow another Apple power adapter, and this proved to solve the problem. The computer will run off the power adapter, as well as charge the battery.
-Cory
这个答案有帮助吗?
得分 0
添加一条评论
my ibook4 adapter connect to it but charging start and adapter showing orange light .pls define orange light ? and green light ?
这个答案有帮助吗?
得分 0
添加一条评论
Different problem. This iBook G4 had been running, went to sleep and then power went from Green to Amber. Did not wake from sleep. Battery still show a full charge, but the iBook will not boot. No tone, nothing. Not on Battery nor on power alone.
Odd for it to die while in use.
Open to all suggestions on what to try next.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cory Sytsma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,684
