跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
274 个问题 查看全部
Mac won’t turn on after screen replacement
I was fixing a friend’s MacBook Pro 13” 2017 with TouchBar. I’ve worked on Macs and iPhones hundreds of times. I opened up the bottom cover and undid the pancakes screw to disconnect the battery and bent the flex cable back a bit to make sure it doesn’t contact the battery during repair. I went ahead and replaced the screen and then replaced the battery connector and screw.
After, I tried turning on the MacBook and I got nothing. No backlight on keyboard, no chime when I plug in power adapter, and no response from trackpad.
I went ahead and did the SMC reset and PRAM reset, but I got nothing. I then went back and replaced the new screen with the old one thinking the new one was defective or shorting out somewhere.
Nothing with the old screen either. So I put the new screen back on. I did some trouble shooting and found out if I leave the battery connector disconnected, the MacBook powers on with the power adapter plugged in. when I connect the battery back to the motherboard, it doesn’t power on even with the power adapter plugged in.
I think it’s safe to say it’s the battery or battery connector to the motherboard. Not sure if that connector piece is replaceable or not.
Any advice would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Curious what @danj has to say, but thinking maybe something with the battery connector?
完成的
did you follow the guide? 2017款MacBook Pro 13英寸带触控栏版本屏幕更换指南. Did you disable Auto Boot?
完成的
@danj I did not disable auto boot unfortunately, I did everything else however. Is the MacBook only useable with the power cable now or can it be fixed?
完成的
添加一条评论
4个答案
已选择的解决方案
I sent off my MacBook to a repair shop that handles board-level repairs, and they confirmed it was the battery that was causing the issue, not the motherboard or power connector.
这个答案有帮助吗?
得分 2
2条评论:
So changing the battery fixed the problem?
完成的
Was the battery replaced? And did the MacBook turn on after the battery replacement? I'm having the exact same issue but I replaced the trackpad on my A2338 MacBook Pro 13"
完成的
添加一条评论
When this happens simply disconnect SMC ribbon cable and pancake battery screw first, then unclip all the Connectors that are accessible when back cover plates are removed... wait a few minutes. Reconnect all Connectors and protective plates then, the pancake battery screw and SMC ribbon cable. Turn MacBook over insert charging cable and lift the lid, your MacBook will turn on... after Initial start up it will turn on with or without charging cable connected
这个答案有帮助吗?
得分 2
2条评论:
The data ribbon cable connector on the battery got damaged so this wouldn't help.
完成的
Plugging it into a charger to boot up solved it for me! Thank you a ton!
完成的
添加一条评论
Ouch! I haven’t encountered that so I just don’t know. I think you’ll need to bring the system into Apple when they reopen.
Take some pics of the logic board markings as well as the systems S/N number, so when you get the system back you can see if they exchanged out the logic board.
这个答案有帮助吗?
得分 0
8条评论:
Yeah I suppose that will be my only option now. Can you help me understand why disabling auto boot is necessary if you’ve already unplugged the battery before doing the repair? Thank you
完成的
Basically, the system is still powered! So when you start disconnecting & reconnecting things you can damage the logic.
完成的
@danj interesting, I always thought once you powered down the device, undid the battery connection, and held the power button for a few seconds afterwards, the entire system would be cleared of power
完成的
TouchID changed things! Now its powered all the time! If you store your system you need to do this as you can kill your system if you don't!
完成的
@danj so, as it turns out, Auto Boot was in fact disabled prior to the repair. Does that change your diagnosis?
完成的
显示更多的3条评论
添加一条评论
So I did this and still no change on the screen I hear the boot up but I didn't get a screen turn on or anything please help
这个答案有帮助吗?
得分 0
1条评论:
Did you checked if maybe your charger is damaged? 😂🤣
完成的
添加一条评论
添加你的答案
Khawaja Shah XI 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 86
过去 30 天: 364
总计 13,354
