跳转到主内容
修复你的物品
维修的权力
商店
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
1983 个问题 查看全部
Why does my iPhone 7 act like the headphones are in
Good morning you lovely lot,
I’ve got an iPhone 7, my customer said he was at work (Dusty builder) and he had a call and they couldn’t hear him and the speaker was greyed out. He plugged headphones in and they could hear him. Also with the headphones out we cannot do voice notes, you click the button and nothing happens. Siri also tells us to disconnect the headphones to set up Siri. I’ve tried a new top flex cable and a now charging cable all with no luck, i’ve checked the top connection point and all seems fine. I have done a hard reset still and update still with no luck.
I am really hoping this is not the Audio IC, What would everyone say and how do i check the Audio IC, i have a multi meter.
Thanks all
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
From what it sounds like it is audio ic but have you tested earpiece speaker and does that work at all?
完成的
@Jade Richards playing music with headphones plugged in would only come out speakers and then when making and receiving calls the earpiece or mic would not work and speaker button was greyed out :( How would you check the Audo IC though to be on the safe side?
完成的
添加一条评论
4个回答
最有帮助的答案
It's a bad audio ic. It's a common problem with iPhone 7 and 7 plus. The case is to weak and it flexes and the contacts on the chip are pulled apart. It can be fixed with micrsoldering. Make sure you have a professional do it. It most likely tore a pad off on the board and a jumper wire will have to be put on. There are only a few I would recommend, jessa from iPad rehab and Jason from sts telecom. Both have channels on YouTube and websites. Their prices are reasonable and the quality of their work is great. I would give them a try
这个答案有帮助吗?
得分 1
添加一条评论
I think you’re bionic chip inside the phone is fried get a new motherboard and replace jt
这个答案有帮助吗?
得分 0
评论:
What is a bionic chip?
完成的
I'm guessing he's referring to the CPU (it is the A10 Fusion in this model), but the CPU doesn't fail like this.
完成的
添加一条评论
I know this is probably too late, but this is a classic Audio IC failure. As for checking it, there’s really no way to other than ensuring you have good parts. The problems are caused by a broken connection under a chip. Since the pad goes to a tiny resistor, you could try measuring it against a known good board, but there’s really no use. This issue is so widespread that the Audio IC will have a broken pad in 99% of these cases.
这个答案有帮助吗?
得分 0
评论:
Sorry this is too late, but I hope it shows you more about the Audio IC failure!
完成的
添加一条评论
Measure the R1103 resistor with diode mode ( red on ground , black on the each side of the resistor) multimeter should give you around 466 and 485. If the values are different from those than you should remove the audio ic and make a jumper on c12.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simon Gilbert 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 54
