跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Can I replace the cracked display frame that mounts the LCD?
Looking to revive my old Macbook Pro 2009. It has been sitting in the basement because I have cracked the Metal Frame that mounts the LCD which is why I can’t close it. Everything else works fine except the wifi but that may be an issue with my battery since it already has a service warning. Any suggestions where I can find a replacement or what to search for (because I have been because welding it is not an option. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is a well known issue. I have repaired several using a heavy buildup of epoxy. I also used cut paper clips as a sort of rebar imbedded in the epoxy.
这个答案有帮助吗?
得分 1
2条评论:
I am planning to test something out because I have some small thin steel bars lying around might use it to reinforce the bracket but I might try to screw it in to be more secure. Are their any wires/ pcb /components underneath or inside the bracket that might get damaged if I drill 2 holes on it?
完成的
You can drill. If you look at it, this is a very thin spot in the frame and they all break in the same location. I also used a Dermel type of tool with a cutting disk and roughed up the surface to help creat a better physical lok of the epoxy.
完成的
添加一条评论
添加你的答案
Ranzel Ong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 34
