跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
MacBook Air 2012 Weird light spots bottom part of screen
I’ve a MacBook air 2012 which got some water spilled over it. Replaced the keyboard and booted without problems, except I noticed this weird marks on the lower part of the screen, just above the bezel. It is most visible on a white background, when logged in for example with the dock present it becomes a lot less visible.
Quick google search and the stage light issue pops up, however in those problems the spots are distributed at regular intervals along the screen which is not the case here.
Pressing on the screen itself does not change the size or intensity of the spots.
Anyone an idea what this could be or how to troubleshoot? Thanks a lot :)
Some additional info about the (history of the) mac below:
Background on the MacBook: laptop is from my mother, so I do not know exactly what happened, but she said the spillage “wasn’t too bad” and at first only some key weren’t working before eventually not responding to any input at all shortly afterwards. (I don’t know if the computer shut down by itself or if it was powered off normally or if simply ran out of battery). When I had the chance to look at it, I opened it up and couldn’t find any obvious indication of water damage and the mac was charging normally, so I figured a keyboard replacement would be a good place to start. So replaced the keyboard and the mac booted without any problems, except the screen issues.
Also, there is a dent in the upper left corner of the body (closest to the charging port, similar to this: https://forums.macrumors.com/attachments... but on the other side), so my guess is it was dropped at some point. The screen issue could therefore be a pre-existing condition unrelated to the water, since my mom doesn’t know if those spots were present before the spillage..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Thats staining of the defuser sheets and the backlight LED’s. Checkout this guide MacBook Pro Retina Display Teardown jump down to Step 12 & 13 to see how your display assembly is constructed.
If it really bothers you the easiest way to fix this is just replace the full assembly MacBook Air 13" (Mid 2012) Display Assembly following the guide MacBook Air 13" Mid 2012 Display Assembly Replacement.
I’ll warn you, you may have a hard time cleaning the sheets if you try taking the lid apart and its not easy to do.
MacBook Air 13" (Mid 2012) Display Assembly图片
产品
$164.99
MacBook Pro 15" Retina Display Mid 2012图片
指南
难度:
中等
MacBook Air 13" Mid 2012 Display Assembly图片
指南
难度:
困难
45 minutes - 1 hour
这个答案有帮助吗?
得分 1
1条评论:
Thanks @danj for the reply, looks like that’s not gonna be worth spending the time or money trying to repair.
完成的
添加一条评论
添加你的答案
V747 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 59
总计 3,870
