跳转到主内容
Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a four-door sedan.
8 个问题 查看全部
When I turn my key off my car won't shut off
Car not shutting off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hey there if your car won’t shut off the first thing you should do is pop the hood open and disconnect the battery to shut it off the second thing is that you probably need a new ignition or you have a wiring issue
这个答案有帮助吗?
得分 0
添加一条评论
I would look at your key to see how worn it is, this will give you a clue as what the condition of the ignition may be. Do you have another key to try?The previous answer form techno chicken is correct. The tumblers inside your ignition are worn causing the connections inside to not disengage. It's highly likely that your ignition needs replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Deaton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 211
