跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
396 个问题 查看全部
Why both the cameras, front and back, and the flash are not working?
I have followed all of the online solutions to fix the software issue, such as changing the setting or restarting the phone, but none of them work. So I think its a hardware issue. Then I tried to switch out the rear camera for another. And its showing no result, still having the same black screen on the camera app. So now I’m thinking is it possible that the main connector is damaged somehow?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There are a few things to rule out. In my past experience it would be best to test all parts so disconnect the front camera and test then the rear and finally you could rule out that. Once one camera goes usually both stop working is what i have had in the past with apple. it may be the front camera needing replacement and don’t worry you wont lose facial recognition from that.
这个答案有帮助吗?
得分 1
添加一条评论
I’m not sure but I think if one camera is not working, you can get stuck when trying to switch cameras in the app. I have seen the flashlight not work before on a phone because one of the cameras was not working. I believe it was linked to the rear camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vik Sirivong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 152
