跳转到主内容
The Buick Lucerne is a full-size upscale sedan sold by Buick from 2006 to 2011.
5 个问题 查看全部
Does anybody have a schematic 2007 Buick Lucerne CXS airbag system
The airbag light on my 2007 Buick Lucerne CXS stays on I have read that it could be The seatbelt restraint system switches , seatbelt switches ,Electronica control module has been activated but the airbag is not deployed As a result of a minor fender bender.and in this case it may need to be reprogrammed.I need an electrical schematic diagram for the airbag system in order to troubleshoot it. Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @vkieley ,
Here’s a link to the Buick Lucerne 2006-2011 Service Repair Manual + System Wiring Diagrams
Scroll down and click on SIR, (under the Restraints section) then click on the reCAPTCHA checkbox to view the file. There is a download option at the top right end of the document window so that you can download it to make it easier to use
When you have the document you’ll find the schematics on the 2nd and 3rd pages.
The document details the complete procedure for testing the system in the vehicle. It is very comprehensive.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
1条评论:
I've got a 2008 Lucerne super I will sell your either needs a starter or fly wheel all I know is I bought it in August it broke down in December and it's been sitting ever since because no one I know wants to mess with a Northstar motor
完成的
添加一条评论
Run a real diagnostic test on it. More then likely it’s a broken wire in the front behind the grille. Honestly you probably won’t or can’t tell it’s even broken. What I would do is just give it the ole tug test.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vincent kieley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 421
