跳转到主内容
Hard Drive isn't working after replacing my PSU?
Today my 1080TI came in the mail, and I installed a 750W EVGA PSU as well. When I boot up, I get an error message, and I realized this is because my hard drive isn’t working (which is where Windows is installed). I have checked my system and my SSD appears, but the HDD does not register to the computer. I can’t even use my PC, since I don’t have an OS. Please help me figure out how to get my HDD working, one thing I have heard is that it can get fried if you use the same cables from the old PSU, but I’m hoping this isn’t what it is.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like the +12V is missing. Make sure the voltage setting is correct, and re-check your connections.
If you have a meter, probe the power connector to the hard drive, with negative on the chassis (or a black wire). You should have +12V DC on the yellow wire, and +5V DC on the red.
Bottom line if it’s missing, either the power supply is bad, or shorted out.
这个答案有帮助吗?
得分 2
1条评论:
Hi,
To add to the answer, use the paperclip test to check that all the voltages from the PSU are OK.
完成的
添加一条评论
添加你的答案
Garrison Bates 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 18
总计 401
