跳转到主内容
An eScooter manufactured in 2018 by the Hover-1 company.
52 个问题 查看全部
I have an error code E2 and the scooter move
The scooter was working then all of a sudden an E 2 error came across the screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you ever find out what caused E2 error code? Seems to be a non-existent answer or solution at this point.
完成的
添加一条评论
2个答案
已选择的解决方案
Throttle fault. Internal breakage or hall sensor failure. New throttle required unless repair is possible.
这个答案有帮助吗?
得分 2
2条评论:
Hi Nigel,
It would be helpful if perhaps you could post where you got the information from.
完成的
Experience to be honest Mike, I repair the odd scooter at work.
完成的
添加一条评论
I had this issue, ended up ordering another throttle, the hall sensor inside the throttle has 3 wires on it. If you have the throttle off you can press it on the exposed magnets, one side of the sensor on one magnet or the other will cause the error to go away, put the scooter on taxi start and scoot away. This will be trial and error because the center leg on my sensor snapped off, that wire shorted against the outer leg (was green on my scooter) should give you the same results. The other will reboot the scooter. My scooter is the AovoPro es80, depending on your scooter’s settings and where you place the sensor on the magnets you may get a faster or slower speed, mines on slow so I’m at about 10mph but that just saves more battery. Am going to try a variable resistor and a momentary switch as well. Also the AovoPro es80 cuts power to the motor when braking this is helpful because you won’t have to jump off the scooter and lift the front wheel off the ground every time you want to stop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alisha 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 145
总计 3,005
