Back-front camera’s sometimes not working
Hello there!
few weeks ago i dropped my iPhone, cracked screen faceid both camera’s and flashlight not working.
i have replaced the screen allready.
now the odd thing is sometimes the camera,s and flashlight will work for days and out of nothing it stops working again for a big amount of time.
i tried to wipe-update and hardreset still same thing happening. Is there a way to check witch camera might be broken?
is it possible that logicboard is broken? I’m confused since it sometimes works.
thanks in forward!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Given that this happened after a drop, I would think you have a logic board problem. The iPhone X actually has two logic boards soldered together. After a drop, the two circuit boards can come partially apart. The reason it may work sometimes is if the logic boards make contact in that area again.
( this kind of stuff is hard to fix, take it to a microsolderer and they can fix it for you)
完成的
添加一条评论
