跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone se touch intermittently unresponsive
I fixed an iphone se from another account by typing in the original password, It does not have a camera, mic or that module with the stuff at the top. other than faint white marks on the screen(it is a water damaged iphone 5s screen) it does not have display problems. The iphone is not slow because when the screen becomes unresponsive i click the home button or lock it and it responds instantly. After a couple of minutes of the screen off the problem is fixed temporarily for about 3-5min. pls help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try with a new screen and if the problem is still there probably it’s touch ic chip problem.
这个答案有帮助吗?
得分 0
5条评论:
i am on a tight budget and it may be a while but ill try to get one, thanks
完成的
You can get a replacement one from eBay for cheap of course not a original one, but whatever you are getting it to try is the problem from the LCD. You can find a good ones for 15-20$
完成的
so, i am experienced in soldering, but i dont know the equipment needed to replace the touch ic nor can i find any videos on how to
完成的
I do have a soldering iron that can microsolder. I watched a video on how to replace a 5S chip and I saw this guy use some brownish substance on his board but i dont know what it is. do i need a heat gun or the substance or can I order the touch ic and fix it?
完成的
Yes you can order a touch IC to replace. That substance is called a Flux, you need some good one. Because not everyone are good no matter the price. Get Flux - Kalafonia and Isopropyl Alcohol mix a little bit of both to get a good flux for soldering. You need also a heat gun , a tweezers, microscope for better accurate microsoldering, heat tapes.
完成的
添加一条评论
添加你的答案
Brayden S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 220
