跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
New Used MacBook Upgrade Sierra to High Sierra
I used SuperDuper to erase and install my dupe OS from MacBook Pro 2010. This mac kept crashing from the old CPU. Do I need to do a clean install of High Sierra then Merge to prevent any crashing problems?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I don’t use cloning apps any longer as they just pass the problem from one system to another!
I would pass on High Sierra and instead go directly to Mojave as its just better.
Best to create a bootable OS installer USB thumb drive following this guide: How to create a bootable macOS Mojave installer drive
But you have another issue which you may not be aware of: If you've got an old macOS install image, it will probably stop working today. You’ll want the OS image from here: How to upgrade to macOS Mojave jump to step 4.
Make a TimeMachine backup of your 2010 MacBook Pro HD or just use it connected via a SATA to USB adapter cable or just connect your 2010 system via a FireWire cable to your 2012 system after first booting it up under Target Disk Mode by starting it up using the T key
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Urrutia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
