Why Samsung S10 won't detect my SD card?
I’ve been using the microSD card on Samsung S10 from the past few months and it was working correctly until today I saw, my phone isn’t showing SD card. what should I do?
Hi @angelojoy ,
Did you try turning off the phone and then restarting it to see whether the card was now being detected, you didn't say?
Did you try correctly removing the SD Card and then reinserting it to see if it being detected?
Can you try another SD Card to see whether it is being detected at all?
Has the phone been dropped or gotten wet at all?
What have you tried?
这个答案有帮助吗?
I've tried all the solutions listed in this article, (https://www.seektogeek.com/sd-card-not-d...), but none of them worked becuase the SD Card itself is corrupted or maybe damaged. Because after inserting new SD card, it is working perfectly like before...
Hi @angelojoy ,
The article did have a solution that worked - Solution 9: Buy a new SD Card - as I also suggested - "Can you try another SD Card...?"
@jayeff yes..and now it is working correctly!
过去的24小时: 0
过去的7天: 6
过去的30天: 30
总计 770
