跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
iPod shuts off when trying to play music and it plays a weird jingle
Hello y’all,
So I have this old iPod classic that I picked up and it was working fine, but then weird things started to happen. Every time I would unplug it from the charging chord, it would shut off the moment it tried to play music. It also says that it’s charging, but it doesn’t hold the charge. I know that it needs a new battery, but here’s what’s weird about it.
This iPod makes kind of like a “pew” sound when it shuts off or when it crashes.
That’s a little suspicious, but what’s even weirder that I have so far had no luck in finding any clues about is when I finally got it to turn on again after connecting it to the outlet, played an alarm jingle. It sounded just like one of those vintage fire truck sirens. I’ll upload a video if I can get it recorded. Any clues as to what is causing this?
UPDATE: I was able to get a video recording of the sound: https://youtu.be/o47STELaIfY
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@andlopez1171 that is definitely a new one. Which version iPod classic is this? I definitely would start with a new battery and then re-evaluate the whole situation.
完成的
@oldturkey03 I was able to catch a video of it playing the alarm sound, I'm going to try a new battery later today, but for now, this is what I have.
完成的
添加一条评论
1个答案
已选择的解决方案
Alright, y’all, I figured it out.
It was very dirty inside. When I mean dirty, there was a solid ball of lint shaking around in there. So first things first, you need to look inside and clean off all the dust. That fixed the issue of it shutting off when trying to play a song with headphones in.
The alarm beeping was the old way of saying that the battery was low. Since it wasn’t holding a charge, a battery replacement fixed the issue.
Finally, I upgraded the iPod to flash storage because it was more reliable and the hard drive was failing as well. Hope this helps for any future people stuck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrea Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 107
