跳转到主内容
修复你的物品
维修的权力
商店
Repair guides and support for your Samsung TV.
1991 个问题 查看全部
Why is my TV not catching the digital signals?
I have a Samsung UN46d6420uf LED 46inch TV. It is 2 months OLD. i have 3 devices connected to my TV all via HDMI cables. Till last week there was no problem with the TV to display the cable's HD channels via HDMI cable. After a recent storm in Louisville, My TV is not catching the Digital signals from the cable box and not sure what happened with it as the TV displays "No Signal" Error message. I tried the following and everything was vain.
1. Changed the Cable box HDMI cable
2. Changed the Cable box to a brand new one
3. Switched the HDMI port on the TV
4. Updated the firmware and reset the TV
I have even tested the HDMI ports on the TV with other devices and various HDMI cables, all are working fine and i was told by the cable guy that my TV is not catching the digital signals.
PS - Recently i had a very close Thunder at my home.
Update
The Main Board is gone in the TV. The technician has replaced it with a new main board. And now comes another Problem, The picture is totally expanded whenever the 3D is turn ON within my TV.
The new main board will be replaced again. Samsung said that they will replace the main board.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Raghu Vamsi, if your TV is only 2 month old, you should still have warranty on it. Use it, don't do anything until you got that point cleared up. Also, if you TV has HD with all your other devices and does not show any kind of error or malfunction, I'd have another talk with the cable company.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Raghu Vamsi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 2,402
