跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
223 个问题 查看全部
Which of the three Mainboard-Connectors is for the Touch-Sensor?
After disassembling my 8 gig 1st Gen iPhone in order to replace the broken glass and digitizer I found my Touch-Sensor not working anymore.
So I redid the whole procedure and it worked without a glitch, for about 3 hours...
Since everything besides the touch-recognition works I think it might be a faulty connection from the digitzier to the logicboard.
Does anybody know which one of the mainboard-connectors is responsible for what task? I named the connectors as follows ;)
  • the one on the side of dock-connector (with the black clamp)
  • the really annoying small one on the camera-side
  • the bigger one on the side of the camera.
Thank you very much for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
+1 for a well written question
完成的
添加一条评论
2个答案
已选择的解决方案
I Believe that in this photo, it is the cable on the top-right:
http://s1.guide-images.ifixit.com/igi/DF...
这个答案有帮助吗?
得分 3
添加一条评论
So, when u open the iphone, to take the touchscreen out, you gotta disconect one cable, by sliding it out, then another by pushing and another one by pushing too... your problem is in the number two! i fixed my iphone and in the end, the touchscreen wasn´t responding... the conector number one was good, the number two was loose and the number three was ok... so i pushed the number two conector and it made a "click" sound.... then it came back to work...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tokyo2ooo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 11,727
